Member Since 25 Jul 2008
Offline Last Active Jul 29 2008 11:24 PM
In Topic: ford escort Nreg - LOST KEY
27 July 2008 - 11:35 PM
right a bit of a fiddly job but rip off the steering column casing and remove the ingition barrel if possible ill check go to a good scrap yard get a new ignition barrel and ecu with the key change the ecu over and attatch the new barrel to it the chip under the red section of the key is unique to the ecu adn the engine will not start until the immobiliser chip matches with that ecu and if possible get the door barrels too then it doesnt look too suspicious if you sell the car on. that or go and talk to a ford garage and see what they can do ill talk to a few people i know down at my local garage and see if they can give you some more pointers
good luck
In Topic: SI 1600 water pump
27 July 2008 - 11:25 PM
hiya i know a company that may be able to supply one for you the address in www.traynors.co.uk they are a scrap yard but im sure they can sort you one out. im sure there arent any special tools that cant be found in good tool shops if needed. hopefully that might help you i can see it being a long ish job a couple days work im not too sure but good luck with it anyway
In Topic: alloy middle piece needed
27 July 2008 - 11:17 PM
keep your eyes peeled on ebay thats all i can say really other than take yourself off to the scrap yard and hope for the best what does it say on the centre plate if its got a ford badge you can find them everywhere if it says rs then they are a bit rarer those are the only ones i have come into contact with but yeh ebay might be a hope for them
In Topic: escort van
27 July 2008 - 11:12 PM
i might be able to help
if you look at an aftermarket spoiler for a fiesta they have the led brake lights in them you can usually pick them up for pennies becasue no one wants them but you might want to have a go at removing one of those but itll be difficult to put it in your cossie fin you have to be handy with a keyhole saw and neat about it to to cut into the spoiler and then youll have to doa botch job on wiring does your car have a rear brake top light as standard it will be laot easier if it does anyway let me know and ill tell you how to fit it cheers mate
In Topic: New vehicle!!!!!!
27 July 2008 - 11:06 PM
thats a rather nice car you just need to do a bit of work on the body at the back from what i can see in the pics but that looks like it could a good toy to play around with what do you need to know about rs turbos i know a few guys thats are in the know and my cousin is a turbo specialist for fords anyway let me know and ill try and answer them for you if i dont someone in my family will we ar all big ford fans
