Member Since 28 Jul 2008
Offline Last Active Jun 28 2015 08:14 AM
In Topic: Mk3 Mondeo Handbrake
28 June 2015 - 08:13 AM
its a common problem on the mk3 for the handbrake levers at the rear calipers to seize up, you can try cleaning and lubricating the levers but this sometimes does not cure the problem and some people have had to replace the calipers, this may not be the problem but its a good place to start.
In Topic: Injectors Please Help
20 May 2015 - 02:52 PM
once the injectors are programmed the car can run a little rough at first but after a short run it should settle down,if the ecu was fault i would expect bigger problems.
19 May 2015 - 06:57 PM
stick with the f super as some people are having trouble with the elm, i can not under stand why injector one is going in and not the others, as long as you are entering one at a time and also in firing order they should recode.
19 May 2015 - 03:18 PM
cars from 02/2003 can be recoded, another question is are you putting the codes in firing order and not physical order?
18 May 2015 - 03:10 PM
i presume that you are programming the injectors one at a time and not trying all at once?
