Member Since 28 Jul 2008
Offline Last Active Nov 23 2015 05:40 PM
#533122 Took My 2.0tdci C-max For A Service And It No Longer Starts
Posted by mintalkin on 20 October 2015 - 12:30 PM
the garage would have seen evedence of this before changing the filter and seeing as you drove 33 miles to the garage with no ill effects of the fuel filter housing crack i would say the garage cause the damage.
#532582 Took My 2.0tdci C-max For A Service And It No Longer Starts
Posted by mintalkin on 18 October 2015 - 01:58 PM
the fuel is usually pulled through at the filter with some kind of vacume device the garage which did the service should know this.
#524193 Ford Cortina The Car Of Our Childhood
Posted by mintalkin on 17 September 2015 - 08:53 PM
and if you were really flash you had a Harry Moss cassette player bolted to the dash, along with the cb radio.
#516868 Rough Idle - 06 Mondeo
Posted by mintalkin on 28 August 2015 - 02:36 PM
i would give the egr valve and manifold a clean to see if this improves the situation, its a messy job but can be done with a few basic tools.
#508585 Ford Fusion 1.4 2002 Rear Bearing Torque
Posted by mintalkin on 03 August 2015 - 03:46 PM
according to the book its 235Nm
#506717 Please Help Fix My Mondeo !!
Posted by mintalkin on 27 July 2015 - 08:48 PM
it could be a dodgy injector, i would get a leak off test done to show up any problems with the injectors.
#479665 Mondeo Possible Turbo Issues
Posted by mintalkin on 25 April 2015 - 04:43 PM
it sounds like you could have a split turbo hose check for signs of damage on all of the hoses, also check the intercooler hose, this is the large hose on the bottom og the egr valve.
#471005 Couldn't Remove A Wheel! Your Thoughts Please
Posted by mintalkin on 29 March 2015 - 02:41 PM
thats why air ratchets should never be used to tighten wheel nuts,but how many fast fit cnt's have you seen do this and how many do you see use a torque wrench afterwards.
#470799 Mk1 Granada Fuel Pump
Posted by mintalkin on 28 March 2015 - 09:55 PM
here you go
#462270 Bad Place To Cross The Road And Who Is Wrong: Lorry Or Van?
Posted by mintalkin on 07 March 2015 - 05:05 PM
if you look at the indicators of the lorry in the outside lane he was indicating to come back into the inside lane before the broken lines of the slip road, the van driver should have seen this and adjusted his speed to allow the lorrry back in before exiting the slip road.as an hgv driver i see this every day you are kind enough to pull over to the outside lane to allow a car onto a duel carrageway but as the truck is limited to 56mph the car you have just let in then increases there speed to undertake the truck and leaves you sitting in the outside lane ( instead of letting the truck overtake leaving the car to then overtake the truck ), it all comes down to impatiance.also the van did not indicate to leav the sliproad till the last minute.
#453917 Focus Zetec S Car Mats
Posted by mintalkin on 12 February 2015 - 03:53 PM
got mine from here, they do various quality depending how much you want to pay, and they do the three door.
#451783 Mk7 Interior Fan Speed
Posted by mintalkin on 05 February 2015 - 04:03 PM
it will be the fan resistor pack that needs replacing, it a common problem.
#437236 Jump Sarting Vehicle Using Jump Leads
Posted by mintalkin on 16 December 2014 - 06:54 PM
i would never use a jump start as the smart charge system will try and zap 18 volts into the dead battery which can fry componants.
#338255 Window No Longer Automatically Closes
Posted by mintalkin on 03 March 2014 - 02:41 PM
try reseting the auto close,operate the switch to close the window,release switch for one second and then operate the switch to close and hold for two seconds.this should reset the window,do the same for the down operation.
#331406 Mondeo 2.0 Tdci 2003 Injector Calibration
Posted by mintalkin on 11 February 2014 - 03:54 PM
the injector code will be on the body of the injector, the formidable wil programme codes, just remember to code them in firing order.
