Member Since 28 Jul 2008Offline Last Active May 22 2013 03:14 PM
Profile Feed
fatlegsdan → mintalkin
Hi ...
I hope you can help ...
I've gone and mucked up my radio and I need the radio code ... can you help?
Rgds
Dan
Rgds
Dan
Jan 09 2012 09:16 AM
mintalkin → mikethelatic
as i say it looks like you have got to remove the radio and look for an Mserial number
Aug 29 2011 06:56 PM
hi mike, going by the last six numbers try 3429,if this does not work you will have to remove the radio and look for a serial number beginning with M followed by six numbers and post back, i will give you your code.
Aug 29 2011 02:06 PM
mintalkin → heddfan
you will need the removal tools for the radio(ebay best bet),once the radio is removed its a case of removing the top cover (star screwdriver)and carefully removing the cds,if all goes well only put 4 cds in to be safe.
Aug 18 2011 03:18 PM
mintalkin → chris bowman
this may be of help
http://cgi.ebay.co.uk/Wheel-Studs-12mm-x-1-5-Ford-Mondeo-fitment-/260408955234?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3ca1955162
also ebay has some complete hub for sale.
Jan 17 2011 09:07 PM
you should be ok with the bearing as long as the hub is not abused too much.
Jan 17 2011 02:49 PM
personally i would remove the hub to get the proper persuation from a workbench/vice as the studs can be tight,i have heard that it can be done without removal but have never done it thatway myself and you may have to remove the hub eventually because the stud will not remove.
Jan 16 2011 05:20 PM
Find content
Male
This status update has reached the maximum number of replies allowed
