antman99
Member Since 04 Aug 2010
Offline Last Active Today, 06:31 AM
In Topic: !!!!!!! Help!!!!!! With I...
13 May 2013 - 12:18 PM
Those Little Clips have literally just fell out of my car (or Ford removed them and never put them back) if you find out would you please post the part number and name.
In Topic: Changing Dash Display
22 April 2013 - 12:16 PM
I believe the OP has a mk 6.5 not 7 so the control for mirrors etc would not be an issue, If I recall on my mk 6.5 you could change things using the indicator stalk, alternatively the small button on the plastic.
But when I think about it I had a Zetec, does the style even have the On Board Computer?
In Topic: M7 Cigar Lighter Fuse
22 April 2013 - 06:33 AM
I assume the dash cam does not work if plugged directly into the cars 12v socket.
Assuming not you may have a dirty socket, I had that, I cleaned it using a small pointy non metallic device (remove the fuse to be sure not to blow it) for me it worked and lots of small dust and debris came out, I still find it is not perfect but it works.
If you need to replace the socket itself I think it is plugged rather than soldered but I cant remember for sure, someone like inath who can remember removing the gear gaiter surround can confirm.
21 April 2013 - 09:29 PM
Does sound a little strange, sorry if you have already tried this but in your adapter under the seat have you tried another device (to rule out dash cam).
Other thinking is how is your under seat adapter connected is it in the socket or hard wired, if it is hard wired have you checked the connection (Including earth).
Let me know if any of that implys anything.
15 April 2013 - 08:04 AM
I believe the change was the 60 Reg Plate (Titanium got Sony Stereo)
As R-head said it is one of the bottom blue ones, cannot remember which but you can tell it is blown when you remove it you will clearly see it.
Now the fun Part!
You will not find them at Halfords or any chain style store that I could find, Two places for me were the Ford Dealer who had to order them in, or a local auto shop but they only had 20 and I think it was a 30 I needed (or the other way round).
They are called Slow Burn or PAL type fuses and they cost about £3-5 each!
