Neil Carter
Member Since 08 Aug 2010
Offline Last Active Aug 11 2010 07:01 PM
In Topic: Cd 6000 Stuck Cd
09 August 2010 - 07:19 PM
Have you tried a long pair of teweezers, should be narrow and long enough to pull the disc out :unsure: used them on an old head unit a few years back
Problem with this unit the CD slot is very tight and also covered by somthing that prevents you seeing inside, I have tried a few things but all no good. Maybe I need to remove the unit, anyone help with how to do this ??
08 August 2010 - 04:05 PM
The only way is to take the unit out and try and take it to bits carefully and then try to pull the cd out somehow trying not to damage the unit, you may end up damaging the cd it's self, you may be able to push it out with a small screwdriver once you have the top off.
Make sure you have the code before you take the unit out.
Good luck I have done it before you can do it.
Thanks, Could you give me details how you took the unit out and where to start ??
