ralph
Member Since 12 Aug 2010
Offline Last Active Apr 19 2015 12:31 PM
In Topic: Bad Garage
07 April 2015 - 11:21 PM
Just read through this thread.... Good luck with your case mate!!
In Topic: 05 Mondeo Drivers Seat Motor
03 April 2015 - 04:47 PM
On the mk3 these are known to go as the teeth in the gearing are plastic. Happened to my mk3 estate a few years back.... Luckily it failed in a drive able position. I bought a 2nd hand one off eBay from a breakers and got my mechanic to fit it when it next went in for w service.... Very common problem I'm afraid.
In Topic: Mondeo Mk4 2010 "60" Parking Sensor
01 April 2015 - 04:16 PM
Ps
I thought all the sensors would be the same (back front etc) but my local ford dealer says they have different part numbers depending on their position and height above the ground!!!???
In Topic: Help Removing Satnav/radio Mondeo 2010
22 February 2015 - 01:11 AM
It's not too bad a job. I had to remove the cup holder/gearstick gaiter, front dash panel as described in the YouTube clip only recently just to replace the bulb in the cig lighter socket!!!!!
In Topic: Third Brake Light Bulb Change
13 February 2015 - 12:31 AM
Me too... Broke the central studs/fixings .... Seems impossible to get out without inadvertently doing so. Went back in and is secure with no rattles so all ok
