chuzzwuzzer
Member Since 17 Aug 2010
Offline Last Active Feb 20 2015 02:10 PM
In Topic: Ford Focus Mk2 2007 Main Beam Problem
20 February 2015 - 10:12 AM
Fusebox for the lights was under glovebox.Checked fuse 37 and 38 which apparently is the main beam fuses.Cant see any damage to the filament. Handbook shows a totally different fusebox so had to look on the net for the correct diagram. Where do i go from here. Just seems weird that the main beam on both sides has stopped working since i changed the headlight bulb ?
19 February 2015 - 07:08 PM
How the hell do you get to fusebox. Manual says you have to unscrew someting in the glovebox.
