Support the club!
Early-1800
Member Since 17 Aug 2010
Offline Last Active May 20 2013 07:08 PM
In Topic: Both Headlights Blown?
11 May 2013 - 07:13 PM
Not sure about other Mks but see below for MK7 Fester headlight blown bulb problems;
http://www.fordowner...od-bulbs/page-3
http://www.fordowner...-on-mk7-fiesta/
In Topic: New Zetec-S This Saturday!
17 March 2013 - 08:20 PM
Ouch sounds like a raw nerve there.
Not sure why we've gone off on an anti Diesel tangent? Would be interested to see if real world MPG are 40+ for the new petrol engines let alone anywhere near the jackanory factory figures.
17 March 2013 - 05:50 PM
Allegro
Attached File  allegro.jpg   9.04K   9 downloads
Allegro Vanden Plas
Attached File  allegro vdp.jpg   14.42K   11 downloads
Fiesta
Attached File  fester.jpg   10.69K   12 downloads
Feista Vanden Plas
Attached File  fester vdp.jpg   15.47K   15 downloads
17 March 2013 - 07:00 AM
Black/chrome interior is nicer but think the new front end has a unfortunate whiff of Austin Allegro Vanden Plas about it....
In Topic: Good Bulbs
08 March 2013 - 09:09 PM
From another thread looks like its known design fault not me or just bad luck,
This bulletin represents technical service information only.
Without exception all gratis repairs and replacements are subject to the
individual warranty and policy procedures of the supervisory Ford Company. The
illustrations, technical information, data and descriptive text in this issue,
to the best of our knowledge, were correct at the time of
publication.
Subject/Concern:
Blown headlamp bulbs on one or both headlamps
Model:
Fiesta 2008.75 (07/2008–)
Build Date: 21.07.2008-23.09.2009
Build Code: 8D-9C
Assembly Plant: Cologne
Build Date: 12.01.2009-23.09.2009
Build Code: 9J-9C
Assembly Plant: Valencia
Kuga 2008.5 (02/2008–) - vehicles with conventional headlamps
only
Build Date: Up to 21.10.2010
Build Code: Up to AR
Assembly Plant:
Saarlouis
Summary
Should a customer express concern about repeated, blown headlamp bulbs on one
or both headlamps, the probable cause is a voltage spike in the electrical
vehicle system.
• NOTE: Fiesta 2008.75: It is not required to remove the headlamp
assembly on the right-hand side.
• NOTE: Kuga 2008.5: It is not required to remove the headlamp
assemblies completely.
To rectify this concern, an resistor wire should be installed on both
headlamps between the current electrical socket and the headlamp bulb H7.
Labor Times published in this TSB are available from 25.10.2010 onwards.
Please refresh your Labor Master file at that day to receive the new data in
your Dealer Management System. Please contact your internal system
administrator.
Parts Required
Description
Finis Code
Quantity
Resistor wire
1 715 479
2
Headlamp bulb H7
see FordEcat
Labor Time
Operation Description
Operation No. / Time
Resistor Wire Install On Both Headlamps - Fiesta 2008.75
Includes: Headlamp Assembly (Left-Hand Side) Remove And Install
710041C65
Resistor Wire Install On Both Headlamps - Kuga 2008.5
Includes: Loosen The Headlamp Assembly On Both Sides
710041C65
Repair/Claim Coding
Causal Part:
36319
ACES Condition Code:
42
OASIS
201200, 203200
Production Action
The resistor wire between the current electrical socket and the headlamp bulb
H7 has been installed in Cologne/Valencia production since 24.09.2009 (build
code 9C) and will be installed in Saarlouis production from 22.10.2010 (build
code AR) onwards.
Service Instruction
See Summary.
Resistor Wire - Install (On Both Headlamps)
