glad you got it sorted, you could put some silicone sealent around the outside of the connecter to help keep water ingress out
agghhhhh.......Drove the car to work and AC stopped after five minutes driving. I tested the connector and switch and 12v are getting to the compressor, sprayed wd40 in the socket and left it, when I came back AC worked again although despite switch sending juice the clutch engaged with varying time delay, from instant to two seconds?....I then drove home with AC working for five minutes then it stopped aghhhh...anyone got any ideas, does the compressor clutch stick through wear..?
Is there any switches,sensors elsewhere which might been causing the clutch to cut out?
Russ
Will try silicon on connector thx
Find content
Not Telling
