APJ
Member Since 08 Sep 2010
Offline Last Active Mar 17 2015 02:29 PM
In Topic: Led Tail/brake Lights (Mk2 Saloon)
10 March 2015 - 12:44 PM
I think your right mate, if you look in the specifications next to 'road legal' its just blank...so i guess that means this particular LED bulb is not road legal. Still tempted to get em and switch em out when due for MOT.....if they are any good
10 March 2015 - 12:13 PM
Someone out there must have these fitted?
In Topic: Rear Interior Dome Light On Mk2 Saloon
02 March 2015 - 02:09 PM
Yep you were spot on jeebowhite...was indeed a 42mm:-) thanks for your help. Converted all my interior lights to bright white LED's now except the footwell lights
In Topic: Replacing Water Damaged Tdci Badge
16 February 2015 - 02:49 PM
Thanks for ya help guys, stuck the new badge on yesterday. All went very smoothly, pretty much did what you guys said..masked off around badge...heated (carefully) with hairdryer, used dental floss in a gental sawing motion to get old badge off..cleaned the area with bug remover, then washed it throughly, lightly dried with hairdryer just to make sure was totally dry then placed new badge on...was easier than i thought :)
16 February 2015 - 11:51 AM
Thanks for the responce jeebowhite.....i think you are right. From the websites ive looked at 42mm seem to be the biggest LED festoon bulb you can get. I guess i should double check by taking the standard bulb that is in there now out and measurIng it before i order anything. Ive replaced my number plate bulbs with LED lights but im sure they were 36mm and they were too small to fit rear interior. Its gota be 42mm for the rear interior. Its annoying with the MK2 Saloon Titanium cos a lot of parts for it are just slightly different from the standard hatch MK2 Focus's. Does seem to have more in common with the titanium c-max/s-max
