Member Since 12 Sep 2010
Offline Last Active Nov 25 2011 09:10 AM
Bg 244 Diesel Fuel System Cleaner
23 March 2011 - 12:51 AM
Hi Guys
Im thinking of buying a tin of BG 244 diesel fuel system cleaner as it boasts to be the very best available on the market today, and completely removes any trace of carbon build up throughout the combustion process on any component involved and will restore the engine as if was brand new, has anyone used this stuff or even heard of it ?
Tdci Tuning Boxes
17 March 2011 - 10:15 AM
Hi Guys
I have been thinking recently i could do with a bit more power and torque on my focus 2.0 tdci 136bhp, has anyone used or are currently using one of these diesel tuning boxes, you see them on ebay alot. I know a remap is by far the best thing to do but its expensive and alot of hassle if i needed to ever put it back to original format, where as these diesel tuning boxes are plug n play and alot cheaper and say they can boost my cars bhp to about 160, i am a bit dubious so wanted to ask if anyone has owned one or is currently using one and does it really give you more torque and power with out !Removed! up anything.
Thanks Guys,
Wing Mirror Multiplug
25 January 2011 - 03:05 PM
Hi Guys
Last week i woke up only to find my wing mirror has been completely anialated during the night by a passing car so i went to my local ford breakers yard and sourced a replacement. Which was electric and heated the same as the original, but as i went to fit it i came across a hitch,
the multiplug on the replacement mirror is different and does not fit the multiplug on the car's wiring loom which i found strange as the replacement mirror is exactly the same, maybe from a different year mk2 focus probably, Is there an adaptor for this sort of thing and does anyone know where i can source from if one exists ? or any other ideas of how to get round this.
Thanks Guys.
Turbo Whistle With Rev Counter Jumping Up
14 December 2010 - 02:46 PM
Hi everyone
I have had a whistle on my car now for months, i have taken it to ford and they told me its the turbo and is normal. It happens only when u give it some welly and at about 2000rpm in any gear, but recently i have noticed at the exact same time as this happens the rev counter jumps rapidly from 2000rpm to 2400rpm then back to normal again as the car continues to pull, the car seems to have a slight dip in performance whilst this is happening. I have checked all pipes from the turbo to inter-cooler etc.. and seem ok, but its really quite hard to spot anything whilst someone's revving the engine and im looking. Does anyone know of maybe a common weak spot on these engines or any other ideas on what it could be. Thanks Guys.
ps: focus 2.0 tdci
Wynns Egr Cleaner
21 September 2010 - 02:22 PM
Hi All
I have bought a can of wynns EGR cleaner 3 from ebay after hearing good reviews from this product, and im just waiting for it to arrive, i know you are supposed to spray it in short bursts whilst getting someone to hold the revs at about 2500 to 3000 rpm but can anyone tell me exactly where to spray it. My understanding is that its sprayed directly into the air intake just after the air filter, but before or after the mass air flow sensor ? and do i need to disconnect the multi plug from it or just leave it connected. Im a bit nervous to be honest and don't want to get this wrong.
