the fuse you need to check is behind the glove box F68-15amp to gain entry press both sides of the glovebox when open and it should drop down to reviel the internal fusebox if this is ok check that the lighter socket is not full of dirt at the small center contact(fuse removed for safety)
is this the same for a 07 mondeo ghia as im having the same problem?
thanks
Find content
Not Telling
