Member Since 21 Sep 2010
Offline Last Active Jul 20 2011 09:57 PM
In Topic: Recoding Injector Help!!
16 July 2011 - 02:49 PM
had same problem with injectors, its a known ford fault usually around 90k miles. RAC engineer that came to me said he didnt have the software to recode it so took it to a ford garage and they did it, also used another garage when it went again as they also had the ford software. I eventually went for a full set of injectors as, if 1 has gone the others might be not too far behind but you can keep on resetting them and get about 10k out of them each time before the glow plug light comes on again.
Hi thanks for reply, just got mondeo back today all fixed so he managed to do it for me only costing me 50. thanks for all your help
14 July 2011 - 09:08 PM
Hi ive heard that some code in firing order too, not sure what sequence he is coding them in, and yh using the code which is stuck on the injector it accepts it but doesnt seem to store it thanks
In Topic: 1.8 Td Making Houling Noise When Revs Increase Help
22 September 2010 - 03:32 PM
Hi ive rapped duct tape around the slit to see of it still makes the noise and it does so carnt be that, i am still going to replace the hose thanks.
21 September 2010 - 04:23 PM
Well the two big pipes that run into the intercooler have oil on them and one pipe has a little slit in it, do you think this could be the problem, its a loud nosie aswell thanks
