fishpond 47
Member Since 29 Sep 2010
Offline Last Active May 27 2012 06:02 PM
In Topic: Air Con
27 May 2012 - 06:02 PM
I've found out that it is the air con resister costing about £15 / £20 but I'm away on holiday at the mo (and missing the air con in this heat lol) and dont have my manual with me, can anybody tell me excactly where the resister is located so I can fix it.
In Topic: Removing Rear Brake Caliper
15 January 2012 - 06:11 PM
The proper 7mm allen key (caliper tool) cost's under a fiver from halfords, have you tried a pair of mole grip's on it now?
In Topic: Mondeo Electric Window Issues
15 January 2012 - 06:06 PM
I know this might sound daft but I had a problem like this on another ford (probe) and it turned out to be the drivers (main switch in your case) faulty, changed the switch and the problem was sorted, maybe the switch has been changed from a differant year or something, might be worth calling into an auto electricians before starting to fork out money on buying new switches you may not need.
In Topic: Focusclicking In Reverse
10 January 2012 - 06:15 PM
Are you sure the clicking is coming from the engine/gearbox area and not from one off the wheels? (cv joint)
In Topic: Alternator Whistle
07 January 2012 - 08:54 PM
simple, the heated screen takes a lot of amps out of the battery to work so fast, which in turn puts a lot of load onto the alternator, put the heated rear on at the same time and the whinning goes even deeper sounding, it's nothing to worry about it's doing it's job
