fishpond 47
Member Since 29 Sep 2010
Offline Last Active May 27 2012 06:02 PM
Air Con
26 May 2012 - 07:47 AM
it's a mk3 mondy, the air con works fine(well used to),nice and cold, but now it only works on No1 on the switch/fan setting, turn it onto No2 3 or 4 and it goes off put it back onto No1 and it'll come back on. Any ideas?
Drivers Door, Central Locking Problem
30 December 2011 - 09:33 PM
As the title say's, when using the remote you can hear all the doors lock (except the drivers door)then unlock because the drivers door is'nt locking, what will be causing the drivers remote lock not to be working? , it locks/unlocks ok with the key, and when you use the key you can hear all the other locks working.
Heater Any Advice?
12 November 2011 - 12:22 PM
Mk3 mondeo 1.8 petrol 51 plate, the heater takes yonks to even get warm yet BOTH heater pipes are hot and the blower inside the car works ok, fitted a new thermostat (old one was shoot), no air locks, and it's still the same, what am I missing? sure I've read on here somewhere that the mondeos have two thermostats.
Was Anybody Else Tempted
28 July 2011 - 04:58 PM
to buying some of those cheap trainers that some pillock advertised in every forum last night/this morning? what do they get out of posting like that, do they really think people are going to take any intrest in there stupid posts.
Well done mods in removing them all.
3 Questions
11 July 2011 - 06:37 PM
question 1, does a 2007 mondy turbo deisel have a cam chain or belt?
question 2, regarding rear brake caliper CARRIER can you just buy the bit of rubber that fits onto the top sliding pin?
question 3, will I get away with fitting a bottom pin into the top?
The reason I'm asking the questions regarding the caliper pins is I have discovered that the rubber on the top pin has worn and is sliding over the pin, in doing this is making the pin near impossible to move and so wedging the caliper in place ie locking the brakes on, so I'm assuming that the rubber will be a dealer part IF you can just buy this bit or end up buying a full carrier(that wont be happening)
