duncanda
Member Since 30 Aug 2008
Offline Last Active Oct 16 2011 09:00 PM
In Topic: fiesta cambelt
05 September 2008 - 10:00 PM
I've been reading some other forums and would agree with you that you don't need the engine out. Think I'll use a different garage and leave you r Kyber Pass alone. ;)
05 September 2008 - 04:35 PM
Nathanlee-miller - how did you change your cambelt? I was quoted something like £350 by a garage to change it because they said it was an "engine out" job.
In Topic: Water in top of cylinder head
02 September 2008 - 05:12 PM
Got the replacement core plug (£1.39), but couldn't remove the old one :angry: . Twisted out of shape the 1/2" extender bar I used, bought a stronger one and still couldn't budge it. Decided to buy some Evo-Stik Hard & Fast metal epoxy putty and pushed it into the hole and it appears to work. For your info if you ever need to try to remove these core plugs, you need a 15mm hex key and more musle than me.
30 August 2008 - 06:52 PM
After closer inspection coolant water is seeping up through the centre of what must be a core plug in the top of the cylinder head. It's a core plug with a 14mm-15mm hex centre. Hopefully I can extract and replace it?
