Mariner
Member Since 28 Oct 2010
Offline Last Active Mar 26 2015 04:48 PM
In Topic: 1.0 Ecoboost Disbale Stop Start
26 March 2015 - 11:51 AM
Didn't think the little ecoboost was DMF.
Its not - It has an intentionally unbalanced flywheel per this link
In Topic: Dash Cam Problems...help!!!
13 March 2015 - 08:26 AM
Wiring to interior light fuse will cause problems as the light circuit is electronically controlled. I wired mine to the rear wiper fuse using one of these. No problems at all.
In Topic: Interior Tool Remover
26 February 2015 - 03:20 PM
I gote these - Cheaper still and very fast delivery :-)
In Topic: Help Hard-Wiring Dashcam
25 February 2015 - 04:22 PM
I forget what slot number mine was connected to, but it is the rear wiper fuse which is 15 amp. Here's the photo of my fuse box again so you can see how the fuse piggyback is connected:
With the wire from the piggyback going up, the original fuse goes in the slot closest to the fuse box (on the piggyback itself), and the fuse for your new circuit goes in the other slot. You don't have to connect the piggyback to the rear wiper slot but that works for me, and an advantage of this is that a rear wiper failure is not that serious, but something else failing like the instrument cluster could cause real problems lol.
Edit: be sure to check your manual because your fuse box might not be laid out the same as mine.
Good advice :-)
How easy is it to find a solid earth near the fusebox?
I plan to have a go at wiring my Nextbase 402G in at the weekend if the weather is dry.
In Topic: Checking 1.0 Ecoboost Oil Level
25 February 2015 - 04:18 PM
I tend to leave mine overnight and check it first thing in the morning (assuming you don't park on a slope)
The 5w20 Magnatec Ecoboost oil is very thin and therefore can be tricky to see when its new.
