Member Since 03 Nov 2010
Offline Last Active Nov 17 2010 07:34 PM
In Topic: Driver Side Window Issue
06 November 2010 - 07:11 PM
I've been useful!
06 November 2010 - 06:42 PM
Sometimes electric windows do this if they loose the limit stops for some reason.
Try pressing and holding the switch down and keep holding it down for 5 seconds after the window is fully open, then pull and hold the switch all the way up and hold it there fo r 5 seconds after the windo is closed. Repat that again and it should re-learn where the limits of its travel are adn the one shot option should work again.
Hope that works and is of some help.
In Topic: Ringtone Through Head Unit (Bluetooth)
06 November 2010 - 03:40 PM
It plays the standard ring? When mine rings the car audio is silent and I hear the phonews own ringtone.
In Topic: Programming Bluetooth - No Manual
04 November 2010 - 05:27 PM
I asked the same thing on the Fiesta forum.
Not sure if its the same as yours but in the absence of anything else it might be worth a try.
In Topic: How To Connect A Phone To Bluetooth?
04 November 2010 - 12:31 AM
1) From your phone search for Bluetooth devices
2) Connect to FordAudio
3) Enter the 4 diget pin that appears on the center console
4) Wait
But read the manual to get the full use out of it
You lazy bugger
Cheers for that!
On the test drive I was trying to get the ford bluetooth to look for my phone.
