edenboy-ragit
Member Since 06 Nov 2010
Offline Last Active Oct 16 2012 09:10 PM
In Topic: Starting Problem
14 October 2012 - 02:35 PM
hi.
it stops the fuel going to the engine. not sure where it does this in the system.
1st check fuel pump is pumping from the fuel tank dont just rely on the noise it makes phisicly check there is a flow of petrol.
2nd check the fuel lines.
3rd assuming you have multi point injection then check pipe prior to the injector rail for flow of fuel.
if you dont have fuel flow at fuel tank pump then check- fuel pump, fuel pump relay, wiring or immobiliser?
check the fuel pipes. i do prefur to find wherethe pipe leads to from the fuel tank ie injector rail, disconnect both sides and blow hard through the pipe. check for blockages. make sure lines arnt crimped at all or damaged.
if you are already getting fuel to the fuel rail the i would check the fuel rail and injectors.
if you can do these checks and let me know where its stopping the fuel come out from i can help you problem solve abit more. otherwise kinda pissing into the wind.
cheers lee
In Topic: Noisy 2.0L Diesel
14 October 2012 - 08:31 AM
Well sounds like the common aux belt tensioner to me. Well know for going slack and causing alot of noise on mondeos would check this out 1st as more likely to be the problem. Cheers lee
14 October 2012 - 08:22 AM
Yes i did mk2 mondeo my immobiliser nakered. If remember correctly there is a certain way to turn the key so it flashes a fault code at you. Basically my key had been dropped too many times and needed fully replacing. Sounds like immobiliser to me mate but reasurch the fault code way of doing it it should help out as it did for me. Good luck let me know how it goes.
In Topic: Euro 4 Engine Flashing Glow Plug Light
14 October 2012 - 08:16 AM
Really. No replies yet. Would really appreciate some thoughts here
