if you are looking for the recommended gap it is 1.3mm
hope this helps
- → Viewing Profile: Posts: Gwyn
Support the club!
- Group Members
- Active Posts 10
- Profile Views 929
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Male
Ford Model
Focus ST170
User Tools
Friends
Gwyn hasn't added any friends yet.
Latest Visitors
In Topic: Spark plug gap for ST170
06 April 2009 - 09:26 PM
04 April 2009 - 12:51 PM
Thanks for that bit of infoWhy do you need the gap ? Not being funny but when plugs are bought they are set to specific gaps to give the required air gap for the fuel/air mix to ignite most efficently , further more if you adjust them coatings like silver or irridium coatings can be damaged on the contact surfaces thus increacing resistance across the 2 point which would give delayed combustion
regards
G Jones
In Topic: ST170 brakes
16 September 2008 - 06:10 PM
no problem glad you found the culprit
I fitted new rear discs and pads this afternoon, it solved the problem. Used Ford origional parts, worst job was to push back the piston in the caliper. Your suppose to use a special ford tool, I got away with a 4" G clamp, made for the job, allthough it required a lot of effort to push the piston back.
Happy motoring
ps Thank god for forum's, saves a fortune in the end and a real satisfaction of doing and solving the problem yourself.
Gwyn
13 September 2008 - 11:24 AM
DTI checks on each cornerThanks again mintalkin.
Will borrow a DTI from work midweek, will post the result hopefully by the weekend.
regards
Gwyn![]()
Front off-side 0.03mm
Front near-side 0.03mm
Rear off-side 0.02mm
Rear near side 0.45mm
It was obvious when I jacked up the car (Rear-near side), that this was the culprud, the wheel was binding when Hand turned at one particular point, Further investigation showed a deviation of .45mm at this point for approx 12cm. Have ordered some discs today and hopefully put them on Tuesday evening. The brakes on this corner must have been running hot, hence affecting the performance & MPG.
Thanks again
Mintalkin
regards
G Jones
08 September 2008 - 02:13 PM
Thanks again mintalkin.anything above 0.1mm (0.004”).would most likely cause pulsating
regards
Gwyn
- Privacy Policy
Find content
