Joekayaker
Member Since 27 Nov 2010
Offline Last Active Sep 24 2011 09:06 PM
In Topic: 99' Focus Rear Disc Brakes
24 September 2011 - 07:09 PM
Hi check the flexi hoses havent collasped as i had this problem with a mondeo once, the pressure of the foot brake would push fluid past but it would not return. Dave
Hi, they look fine. Also tried letting off some fluid which doesn't make any difference so I don't think it's a residual pressure issue..
Thanks, Joe
24 September 2011 - 07:06 PM
have you tried flushing the brake line without a caliper on it?
Not tried that. You think the pipes ma be blocked with rust?
24 September 2011 - 03:30 PM
Hi, yes it does it even when the handbrake cable is not hooked on...
thanks, Joe
In Topic: Focus Rear Brake Piston Rewind
28 November 2010 - 01:33 PM
The piston has a sort of cross on it, is there supposed to be a tool that it engages with?
Is there a nrv in the system for the backs? on the fronts as I drove the piston back the level in the reservoir rose. Cheers
28 November 2010 - 12:21 AM
Hi yeah I did try that but it still wouldn't go..
