weedavey1888
Member Since 05 Dec 2010
Offline Last Active Feb 22 2013 07:45 PM
In Topic: Rear Shock Absorber
09 April 2012 - 03:16 AM
cheers stef
two  10mm bolts at top bracket and a 10 mm retaining nut on piston.a 15mm through  bolt on the bottom . very easy to do. inner arch comes off easy. only thing was. when i tried to undo the through bolt  18mm nut  it took me a good 20 mins of huffing and puffing using an extention bar before i realised that  the 18mm nut is actually welded to the bottom bracket and  you loosen it from the 15mm end Posted Image .what a twit i am
03 April 2012 - 07:56 PM
