MrRedman
Member Since 08 Jan 2011
Offline Last Active May 19 2013 09:35 AM
Rear Washer Supply Pipe Solution
15 January 2013 - 04:02 PM
Hi Gang the pipe that connects the rear jet to the pipe in the roof lining has split/snapped is there a quick fix to this with a certain obtainable pipe or will i have to go to the breakers or Ford?
The wires which supply the motor are chaffing as well,Id seen this issue on another thread so will be doing both jobs at the same time,ill insulate or replace any wire which is on the verge of snapping or is there a kit for this to.
Car is Focus 2002 cheers Paul
Focus Keyfob
21 October 2012 - 01:05 PM
Hi everyone
Upto now its doing nothing ive tried the key reprogramming on an off 4 times the car buzzes but does not buzz again to indicate its accepted the key,ive had the keyfob tested its fine.Next i have unplugged the box on the drivers side footwell hoping that it would reset,it didnt so ive turned the fusebox round and removed fuse 63 checked it put it back in,nothing!
So what next, if is going to be an expensive repair? ill use the key the car is a Focus 1.6Zetec 2002 thanks.
Best Solution To Water In The Plug Ports
13 September 2012 - 06:19 PM
Hi guys my better half now has the 05 focus which ive read on here suffers this problem,so after having the same Ive changed the plugs and the leads.All has been fine for 2months but now the weather is changing the water seems to be back,so i want to seal the washers which i should of done 2 months ago! doh!!
       which is best some sealant round the washers or new washers just need a permanent cure.
       thanks Paul
Coil Pack
31 July 2012 - 08:18 PM
The Car began misfire-ing at weekend had a look and decided it was the coil pack which it was,what a difference its more responsive than its been for years must of been failing for a while ! car has done 77k
Rough Running
12 May 2012 - 09:13 AM
Hi cud anyone tell me
On our Mk2 focus the engine management light has come on and it's running rough cud it be the water in the plugs issue as the leads are rusty coloured!
Or would this not trip the management light?
