Member Since 08 Jan 2011
Offline Last Active Jan 09 2011 12:18 AM
Galaxy Tdci Starting/running Problem
09 January 2011 - 12:21 AM
hi thanks for looking and hope you can help. i have a 56 plate new shape galaxy 2.0 tdci 140. firstly i'd like to be sure that whether the injectors are coded on these models. it has starting problems. once started there is no power and it dies away and sometimes cuts out after a few seconds. if i am able to hold the revs for a short while it soon dies away once i try to pull away. I have removed all injectors and replaced copper washers. I have a small compression leak through the left hand side (no 1 cylinder i think) injector but not enough to cause the power loss. I'm wondering whether its a fuel pressure problem and if so is this more likely to be the fuel pump or maybe a failing regulator/solenoid. Is the reg/solenoid fitted to the common rail. Maybe someone has had the same problem and can offer advice, all of which would be greatly appreciated. I have owned the car from new and its been a great workhorse, its covered almost 170,000 miles. look forward to hearing from anyone. Thanks Dave
