The powertrain light (exclamation mark in a cog) keeps coming on in my '06 1.6 TDCi Focus. When it comes on it also goes into safe mode and drastically reduces the power. It's not dpf related as I had that little nightmare removed and the ecu reprogrammed a while back.
I had it scanned a few weeks ago and the mechanic said it was indicating an error with glow plugs / glow plug module. He reckoned it needed a new module at a cost of €300, or else he suggested there might be a wiring issue somewhere on the glow plug circuit. I left it to have a think about what to do.
The glow plug light comes on as normal when I turn on the ignition. Shortly after starting and driving the car a few miles the powertrain light will come on and I'll lose power. I decided to have a look at the fuses in the fuse box. Anything glow plug related seemed fine, no fuses blown. I pressed all the fuses and relays down just to make sure that none had come loose. After I did this I started and drove the car and it was fine, no powertrain light. It stayed fine, no problems, for a few days, and then eventually the light came back on. Now, whenever the light comes on again, I open the bonnet and press down all the fuses and relays and it's fine again. Sometimes for a few hours, sometimes a few days. But always the powertrain light will eventually come back on again and cut the power.
The fact that it seems to be ok after I've fiddled in the fuse box suggests to me that the problem is not with the glow plug module as the mech suggested. Could I have a duff relay or fuse? Or could a fuse or relay be working loose and causing this?
Any ideas or suggestions would be appreciated!
- → Viewing Profile: Topics: Evolve
Support the club!
- Group Members
- Active Posts 18
- Profile Views 986
- Member Title Member
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
2006 Focus 1.6tdci
UK/Ireland Location
---------Ireland-----------
0
Neutral
User Tools
Friends
Evolve hasn't added any friends yet.
Annoying Powertrain Light / Glow Plugs Issue
08 November 2012 - 08:13 PM
Possible Turbo Leak - Where To Look?
27 September 2012 - 08:57 PM
I'm pretty sure I have a turbo leak somewhere as my car is making a 'whooshing' sound under acceleration which sounds like it's coming from on top/in front of the dash. It was in with a mechanic yesterday for something else entirely and, as an aside after a test drive, he mentioned to me that he thought it might have a leak somewhere in the turbo system also. It's chucking out a bit more smoke than usual (it's a diesel), so would this mean it's burning more fuel? And would this indicate a leak too i.e. burning more fuel to give the same power?
Are there any 'usual suspect' areas where the turbo system develops leaks? It's a 1.6tdci
What Does This Warning Light Mean?
20 February 2012 - 06:02 PM
I have an '06 tdci focus and today a warning light popped up on the dash. It is a circular cog with an exclamation mark in the centre of it. Unfortunately there was no owners manual in the car when I bought it so I don't know what the light is referring to. I'd be very grateful if anyone could shed any light?
- Privacy Policy
Find content
