mondeo family
Member Since 30 Sep 2008
Offline Last Active Jul 19 2009 04:40 PM
In Topic: MONDY TD FOR SALE
09 April 2009 - 08:21 PM
hi mate just wondering what engine size you car is
In Topic: mondeo windscreen washer problem.
09 April 2009 - 08:19 PM
hi mate, i also had that problem recently and i was told that you could also use one of the calgon tablets, if you have that problem again the best way i was told is to take off the mud catcher under the front of the bumper and if needed you can lower the washer bottle down also if you get a small spray gun into the pipes and blow out the c**p out of the pipe
In Topic: Mk2 Mondeo Si
09 April 2009 - 08:10 PM
hi i also have a 2.0ltr 16v si mk2 check with your ford dealer as i found mine had a higher bhp than what the dvla had on there system it turned out to be a difference of 15bhp as mine is running at 145-150bhp and she runs like a dream but i must advise you on getting your gearbox link pins (the bits that hold the selectors in the gearbox) have snapped twice in mine so i have had to replace my gearbox but it turned out to have had the wrong one fitted, and just to confirm the SI has got a 1989 cc engine so just get it checked for your own peace of mind. Hope this helps you with your dilemer
In Topic: Ford Mondeo Front Grill..
09 April 2009 - 07:57 PM
just to let you know there is a ford breaker's in liverpool called all fords on ventura bisuness park you could try there m8
In Topic: 1999 mondeo st24
28 November 2008 - 09:23 AM
Panther black mondeo ST24, its a proper ST not a replica 2.5 v6 duratec engine 126000 miles, service history up to 86000, mot till may 2009, tax has run out so is declaired SORN all electrics work, central locking working after i replaced o/s/f door actuator. cd changer has been replaced as it wasnt working when i got the car. just had full service done by a ford mechanic.
bad points
dent/scrape on o/s/r wing, bumpers are scuffed on front and rear but will probably buff out, drivers seat the stitching has come away on one side, the gearbox started been noisy and took it to a ford garage to be looked out, they said the diff was worn and a new box was needed, on way home from ford garage the car stopped driving and started grating. i havent got the time or patience to replace the gearbox so im open to offers to take the car away. im looking for around £300
call me on 0796203937 for more info if needed or a viewings
Hi mate where abouts are you, did they say how much it would cost to replace
