Jonny lad
Member Since 15 Mar 2011
Offline Last Active Feb 26 2013 12:11 AM
In Topic: Ford Mondeo Tdci 2.0 Auto Clutch Replacement
17 December 2012 - 07:53 PM
Cheers, had found a plastic cap that had hidden the bolts,
again thanks
Jon
17 December 2012 - 05:46 PM
Hi guys, I have a manual with a whole in the engine, so I bought a engine which has a auto clutch arrangement fitted, I will be using all the old parts from my damaged engine, I need to remove the clutch arrangement to fit my manual clutch etc etc, sorry for the lack of info.
The problem is getting the auto clutch off, it has a round shaft at the front with a flat spot on either side for a spanner etc, I'm not sure which direction to turn this to remove the unit? also I appreciate I will need to stop the ring gear turning etc.
Your help would be appreciated.
Jon
