ish034
Member Since 08 Oct 2008
Offline Last Active Jul 21 2009 08:49 AM
In Topic: Ford Focus Water Leak
21 July 2009 - 08:48 AM
Hi everyone,
I just had a new pollen filter cover fitted by Ford themselves, hoping this would solve the problem as everyone put it down to this, and the problem has been getting worse (now water is coming into the passenger footwell as well - the waterproof material/lining underneath has cracked). Unfortunately I went to the car today (after it had been raining) to find the same puddle in my back footwell.
Does anyone know were this could be coming from?? I have to add, that I reached up as far as I could under the passenger carpet and found that the higher (towards the windscreen) I went, the dryer the carpet was. The carpet in fact seemed to be getting wetter (i.e. the source) from towards the centre of the car (were the passengers right foot would roughly lie).
I really need help with this problem and appreciate any comments, answers or suggestions.
15 February 2009 - 09:01 PM
hi, i've got a 2000 ford focus tddi
14 January 2009 - 09:11 PM
i had the leaking scuttle panel before and came up with a fix for it. If you look at the picture ive attached, it shows the under side of the scuttle and where to seal it with silicone. You will need to go to ford and ask them for the pollen filter and the seal for the panel,cost me £15 at my local dealer. the seal kit is just double sided foam that goes along a groove in the underside of the scuttle, where it touches the windscreen. My fix seems to be very effective. its not the fact that the water gets down under the scuttle, its where it goes once its under. the little tray on the bottom of the panel should disperse it to the sides but instead it leaks through where the 2 bits of plastic have been stuck together:)
Hi, i am really interested in your fix, as it could save me a lot of money, however dont fully understand the picture. Could you please explain to me how sealing the underside of the scuttle panel, around the drip tray, would help, as i thought this bit didn't touch the windscreen (it goes underneath). It would really help me if you could draw on the picture i have uploaded and i would appreciate it alot.
Attached File  Scuttle_panel.jpg   58.03KB   405 downloads
Also could you clarify what two bits of plastic you are refering to in your reply, when explaining where the water leaks/runs to.
Many, many thanks
09 January 2009 - 12:41 PM
If what you saying is correct, could i get the problem fixed by having ford fitting a new suttle panel (note: if the dams under the scuttle panel are the problem, but i had a new scuttle panel fitted, would my water leak problem still remain?)
09 January 2009 - 01:04 AM
Hi, itís been a while now and the water leak problem has been getting worse. My rear passenger footwell floods every time it rains. After lifting up the carpets, I have now found the leak is definitely coming from the front of the car as the carpets are wet (getting wetter) the further/closer I go towards the cabin (note: passenger footwell appears to be dry when carpet is down as there is a waterproof lining on the bottom of that area of the carpet - water runs towards lowest part of car (rear passenger footwell)). I suspected that the water leak was due to the pollen filter cover, which I have read is a common fault, and so, using some silicone, sealed up the gap between the windscreen and the cover. I thought this would solve my problem but have found that the rear passenger footwell still floods when it rains. This then led to me believe that I perhaps did not seal it up properly and thatís why water is still entering the car. To check this, after it would rain and the footwell would flood, I would go out and lift up the bonnet, lift up the pollen filter cover slightly, and squeeze my hand into the actual pollen filter to see whether this was wet. I found that every time it was completely dry.
As you can probably guess, this has left me very confused as to where the water is coming from. Could it be that it is still due to the pollen filter cover and that the water is somehow getting through, past the cover and into car without touching the actual pollen filter? Or, seeing as though the pollen filter cover looks as though it is sealed properly to the windscreen, could the water be running down towards the bottom left hand corner of the windscreen (car is usually parked with passenger side to (slanting towards) the pavement), and under the metal panel (the metal panel in between/that joins, the bonnet, bumper and door), then somehow into the car. (Note: i did create and have a picture to show this very clearly, however found that i cant upload/view it).
Could someone please help me with this problem as to any ideas of where the water is entering the car and how I could test for it etc.
