Tanktop3
Member Since 02 Apr 2011
Offline Last Active Aug 25 2013 06:43 PM
In Topic: Guide: Fitting Egr Blanking Plate 1.6tdci Engine
02 August 2013 - 03:28 PM
Did it today will see how it goes should be ok as a lot of you have fitted if. thanks Lenny  for the how to do it Great post and good pics to
In Topic: Dpf Additve Tank
20 April 2013 - 08:32 PM
When you get it right Malfunction light comes on then turn the car off then back on and the light will be off and ECU counter is reset.
this is it
NOTE: This procedure must only be carried out if the vehicle has reached the recommended additive filling service interval, with the additive tank level being above the low or empty level with the malfunction indicator lamp (MIL) and powertrain control lamp (PCL) not illuminated.
NOTE: The fuel additive system service reset procedure will exit the resetting mode automatically if the following tasks are not completed within the specified time limit.
NOTE: The following procedure must be read through and completely understood before attempting the fuel additive system service reset procedure.
NOTE: Make sure the ignition switch is in position 0.
NOTE: The following sequence must be started within 60 seconds after the ignition key has been switched to position II.
NOTE: Make sure the fuel filler flap is closed.
Turn the ignition switch to position II.
Open and close the fuel filler flap.
Turn the ignition switch to position 0.
NOTE: The following sequence must be started within 60 seconds of the ignition switch being turned to position II.
NOTE: The following sequence must be completed within 10 seconds after the fuel filler flap has been opened.
NOTE: The following sequence must be started within 15 to 30 seconds after the fuel filler flap has been closed.
NOTE: The following sequence must be carried out within 60 seconds of the fuel filler flap being closed.
NOTE: Make sure the vehicle is in netural.
Start the engine.
NOTE: Allow the engine to idle (min 20 seconds).
NOTE: After approximately 25 seconds the PCL lamp will illuminate to indicate the resetting has been achieved.
Allow the engine to idle.
NOTE: Check the PCL lamp for illumination. If the PCL lamp is illuminated continue with the procedure. If the PCL lamp is not illuminated repeat the procedure and test the system.
NOTE: Check the PCL lamp for illumination. If the PCL lamp is not illuminated the fuel additive service reset procedure has been completed. If the PCL lamp is illuminated repeat the procedure and test the system.
20 April 2013 - 06:25 PM
Hi I reset the ECU counter by the fuel filler cap as in the Haynes manual  but you can only use it if MIL OR PCL light is not on saying empty or low fluid. It did take me 3 goes to get it to reset in all about 30 mins to do it all.
I think it is on here how to do it.
19 April 2013 - 05:19 PM
I went with the long pipe so now reset all done and  for £39.99 and not the £164.00 ford said.
In Topic: Anyone Know How To Learn Anti Trap Windows For Fitting Heiko Deflecters?
14 April 2013 - 06:19 PM
Hi just fitted  fitting heiko wind deflectors on my focus Mk2.5  they look good and were ok to fit.
if any one as A FORD FOCUS MK1 MK I SALOON 1998-2004 i've got a set of HEKO WIND DEFLECTORS TINTED 4pcs set for sale. pick up only so would have to be round the Northwich  in Cheshire area
they are £25 I made a mistake when ordering them.
