Support the club!
stuu56
Member Since 06 Apr 2011
Offline Last Active Jun 15 2013 10:46 PM
In Topic: Re-Connect Battery & Problem With Dash Lights
15 June 2013 - 10:48 PM
What indicator light are you referring to? I`ve no probs with my indicators. It`s the 3 blower direction buttons that now light up at the same time and won`t go off along with the A/C not coming on...I `m quite sure it`s just a matter of pushing the right buttons to reset it after a battery disconnection...need to find someone who knows this procedure.
15 June 2013 - 09:44 PM
thanks for this info re re-setting the heater system...i guessed it may be something like this, but had no idea what to do...
14 June 2013 - 06:02 PM
Sorry - also meant to say I cannot get my Air Conditioner to start blowing also and it was fine before disconnection.
In Topic: Can`t Change Gears Unless Engine Swithched Off ???
16 December 2012 - 02:27 AM
Hi, thanks for this info...
Going to bleed clutch later today after I put on a wee clamp to the clutch pipe that comes out of the top side of the reservoir ...it's a steel pipe that goes into the reservoir and is a few inches long...this goes into a flexible piece of something about 5 inches long, and another steel pipe line goes in the other side of it and down to the clutch.
Each end of this flexible tubing has a wee clamp ..however, when I checked to see if the pipe coming up from the clutch could be moved where it enters the flexible tubing, it slid out without any effort at all so the wee circular clamp is not sealing and holding it...will put one on that can be tightened with a screwdriver and see if it totally secures it...if ok, will bleed the clutch...
12 December 2012 - 12:12 PM
Just back from him...he`s been really nice about it...told me to bring it back and he`ll sort it out...only prob is, it`s 10 miles away and i have to start the car in the gear i place it in before starting up as it won`t change when running...so will have tio start it in 2nd ad drive thru Glasgow for 10 miles till i reach his place. He said rev up slightly and it will change as the revs die down,...yet to try this.
I`m sure it`s just one of the line joints/circlips has loosened a bit and is letting in air so no clutch line pressure.
