dan1990
Member Since 14 Oct 2008
Offline Last Active Dec 01 2010 04:08 PM
In Topic: Ford Focus 1.8 Zetec Starting Problem
15 November 2010 - 11:49 PM
my uncles old diesel astra used to do it and it was a doddy starter motor think it was the brushes on theyer way out
In Topic: Mk5 Fiesta With Multiple Problems
11 November 2010 - 12:12 PM
hi mate 2 me it sounds like the heater control valve best thing to do is replace it my heater is the same it works when it wants 2 also have you got a engine temerature gauge on it f so check the temperarture and if it doesnt reach a good temp on the gauge after a run its the thermostat
hope that helps :D
In Topic: Mk3 Fiesta Running Problem
11 November 2010 - 11:40 AM
have you checked all the plugs and leads to see if they are fireing if not its coil pack
give it a good run fill the tank and use some redx
make sure all pipes are free and are not blocked
In Topic: Hey Im New And Need To No If There Is Any Other Programmes For Ford Except Th...
11 November 2010 - 11:09 AM
i done it now thank you :D
11 November 2010 - 01:20 AM
thank you how do u get the pic of your car to come up in the about you section of ur profile and it then shows it on every commment u put??
