- → Viewing Profile: Posts: neilcbc9799
Support the club!
- Group Members
- Active Posts 6
- Profile Views 472
- Member Title Newbie
- Age Age Unknown
- Birthday Birthday Unknown
Gender*
Not Telling
Ford Model
Puma
User Tools
Friends
neilcbc9799 hasn't added any friends yet.
In Topic: Ford Puma Locking Wheel Nuts
05 May 2011 - 03:37 PM
I managed with the help of a rather large screw driver to break the metal surrounding the nut. Once this was off it was relatively easy to hammer on a 16mm socket and unscrew the damaged nut.
I managed to save myself some pennies by the looks of things.
I hope my problem doesn't occur with anyone else. It looked daunting at first!
Thanks Jeebowhite for your help and advice.
28 April 2011 - 08:12 AM
I've never seen anything like these before and they look almost custom made with added protection!
Looks like I'll be paying the welder a visit!
Cheers again.
27 April 2011 - 04:04 PM
27 April 2011 - 03:34 PM
I cant see the picture as work have blocked the website. you will have one of three main designs... Round nuts with a locking pattern ground into them, nuts with a sort of "Torx" (Star) shape hole in the middle, there may be other designs (I wish I could see those pictures!).
You may need to try and buy a similar style key, but worst case scenario they will need to be removed by a garage. I will try and take a look at the pics when I get home, and will try and post a further update if I get the chance...
There are ways that you can resolve this. if you cannot get ahold of the key...
1) use a slightly larger socket than the nut (i.e. if the nut is 21mm diameter, will a 21 mm just fit over the top, or try a 22mm) - Basically you can mallet this socket over the top and remove the nut with a standard extendable wheel wrench, or ratchet. this can remove the nuts
2) angle grinder - the most painful method to watch, but I had to have it done on one wheel, the nut was so badly damaged that they had to try axle grind the nut then they had to take the wheel off!
3) Spot Welder - If you can get a spot welder to weld the nut to an old socket then you can remove it - yes its a waste of four good sockets, but its much cheaper than replacing four wheels!
Unfortunately I had this on the focus, so feel your pain, in the end I removed the lock nuts from the car!
Thanks for the info. I can't see a way out of this. I thought about using a slightly larger socket but there is this protective metal ring around the nut itself (which is attached loosely behind the nut) and is blocking my ability to put a socket anywhere over the nut.
I look forward to receiving any thoughts hopefully after you've managed to see the photo.
- Privacy Policy
Find content
