the loan ranger
Member Since 03 May 2011
Offline Last Active Jun 10 2011 07:26 PM
In Topic: Ranger Xlt - Aircon Problem
27 May 2011 - 07:51 PM
Tks for this info p38fln will check it out. meantime I had it re-gassed and it runs fine so far after 2 weeks being used for about 30 mins every other day'ish, but will check your suggestion thanks.
27 May 2011 - 07:49 PM
Is the compressor actually turning on? Run the AC on the coldest setting with the fan on the highest setting and open the hood. Is the center of the AC compressor turning? If not, you most likely have a leak in the AC system that needs to be repaired.
Note that in colder weather, the compressor may only run for a few seconds before shutting off - it will turn back on a few seconds later and repeat the process. On the hottest summer days, it will run continuously. The best time to have the A/C worked on is when the temperature is above 85F (Thanks to Google: 29.4C).
