grahamp
Member Since 16 May 2011
Offline Last Active May 14 2013 06:39 PM
Changing Fuel Filter On A Focus 1.6 Tdci... Bleeding?
25 March 2013 - 11:05 AM
My filter needs doing and I'd rather do it myself, but I've heard from a few in the garage trade that it can be a nightmare getting it bled afterwards and restarted, as there is no built in hand bleeding pump. Ford tend to use a handheld air-driven primer AFAIK, and I've heard of some garages reduced to trying to tow start after a filter change.
I've also heard you can prime it by switching the ignition on to II and off 7 or 8 times without starting, to prime using the fuel pump. Has anyone tried this method with any success?? Don't want a non-starter on my drive.
Auto On: Air-Con And Heated Rear Window
25 March 2013 - 09:34 AM
2008 Focus, Style trim...   When the fan is on and the vent controls are set to windscreen, the air con comes on automatically, and when presumably the temperature is below a certain level the heated rear window does as well.
I would much prefer it if they stayed off, and came on when I wanted them to. Is there a way to disable these features??
Closing The Tailgate Of A Focus Estate
25 August 2012 - 06:36 PM
End of the holiday today so packed the estate boot up, as usual there seemed to be more coming back than going. Had a trial shut of the tailgate to see if it would close. Something blocking it and it didn't fully catch. OK, no problem, I'll just open it, rearrange, and try again. But no. Won't open. Its not happy that something got in the way so its going to stick.
Now at this point, with the thought of a 300 mile drive with a slightly open tailgate ahead of you, you may be tempted to try shoving the thing closed with your !Removed!. STOP. Move away from the car and call the wife, who will calmly climb into the boot and release the obstruction. Otherwise you will discover that Ford constructed the tailgate from 0.2mm recycled beans cans, and an !Removed! shaped dent will magically appear beneath the number plate.
Also while I'm on body work, another word of advice. If your Mrs books a holiday in the South Hams district of Devon, on no account spend a weekend washing, cleaning, scratch removing, paint renovating, and wax polishing before you go, as you will be coming back with several wavy scratches down the passenger side from the bushes you will inevitably have to drive through in order to avoid oncoming traffic on the lanes that haven't been updated since the days of horse and cart.
No Isofix On A 2008 (Mk 2.5) Focus Style Estate??
09 July 2012 - 04:20 PM
Odd. According to the manual - page 25 - all models apart from convertibles have ISOFIX points. Just been having a rummage around as I need to transfer the child seats from the other-half's car into the Focus and I can't locate any. I know the Style is base spec, but the manual says "all models". Behind the seats there's a black polystyrene block that fills the void before the boot floor but there's nothing under that. I've lifted the seats, felt in the space between backrest and seat base, but nothing.
Am I being daft or does this car really not have any, which would be rather disappointing in this day and age :huh:
