bluemax
Member Since 21 May 2011
Offline Last Active May 28 2011 06:32 PM
In Topic: S-Max Pollen/cabin Filter - How To Change It?
24 May 2011 - 08:54 PM
update - the pollen filter is indeed at the back of the passenger footwell as JohnH describes - take off the centre console panel at the bottom of the centre console in the footwell, there are 2 clips that you wedge open and pull out. Next take out the liner under the glove box, there are 2 push-on/pull-off black covers over yellow stalks. Next take off the fuse-box, twist the clip 90degrees and lower the fusebox and then pull it off the 2 hinges once lowered, and push it to the left as far as poss. Undo 3x 7mm screws/bolts with a small socket wrench. Pull out old crappy dirty black filter - you can concertina it to get it out of the space. Similarly putting the new one in - it can be concertina'd to fit back in. Pic here of where the cover is - its in the centre of the pic with the regular rectangular cut-outs. Took me about 45mins to get this done once I realised what on earth you're supposed to do.Attached File  footwell.JPG   124.01K   679 downloads
23 May 2011 - 07:09 PM
thank you digidash, so where exactly is that then please? can you see it in my picture in the first post or am I in the wrong place? I just can't see where it is located that is the problem. I have yet to try johnH's suggestion about back of the footwell.
22 May 2011 - 09:33 PM
ah ok, thank you, I will have a furtle around in that area and see if I have any luck. Such a blinding idea to put cabin filter in such an easy and obvious place, well done the ford design computer. Has anyone actually changed one of these on an s-max or galaxy mk3?
