Member Since 21 May 2011
Offline Last Active Mar 14 2013 08:59 AM
#153430 Fiesta Rs Style Project
Posted by D4nz0 on 21 November 2011 - 08:36 PM
Saying hi might have been nice...
I think a congratulations are in order for choosing to install the most disgusting front skirt I've ever seen and putting a stupid looking bra on it
:huh: :huh:
#152388 Which Dmb Colour Would Suit My Car?
Posted by D4nz0 on 12 November 2011 - 11:28 PM
A) no you shouldn't
Only colour of car that suits its badge
#150358 Mist Style Washers
Posted by D4nz0 on 28 October 2011 - 07:05 PM
+ 1
Great mod
#149100 How To - Sunglasses Holder
Posted by D4nz0 on 19 October 2011 - 06:10 PM
There's no real prob with the top end fitting, and I genuinely found the metal surround supports the front as a tight fit tbh. The little gap towards the front has settled since its been fitted, unsure why it happened.
Inath, they're "furry" dice, not fluffy. ;). Wanted em since I passed my test years ago and found em in a scrappies lol... I know folk had done this, but wasn't sure if there was a how to made
#149026 How To - Sunglasses Holder
Posted by D4nz0 on 18 October 2011 - 10:23 PM
Remove light from new surround and also the plastic backing of sunglasses holder. The black backing has four clips holding it in place, a screwdriver will wedge em out, start with the clips in the centre of the surround, makes life easier
Measure and mark the area you want to cut. My tactic was to hold the surround up and make marking of where I want like this
Admittedly, I cut a hole too small, then went back and cut a little more to suit.
Remember, take this metal badboy out or you wont be cutting far
Hole cut
Now put the little metal badboy in, and also the black plastic for the rear of sunglasses holder. These will support the surround once clipped into place.
Take care when fitting, making sure you're getting all the surrounding headlining underneath the surround for a better finish
Job done
I notice that my surround isn't totally flush with the headlining, and I think my surround has been a little warped because the passenger side is tight which is disappointing, so I'll decide later on what I'm going to do about that..... either some glue or a new surround.
Thanks for reading,
#148275 Fiesta Metal
Posted by D4nz0 on 12 October 2011 - 07:13 PM
I use Photobucket too, easiest way plus u can share em on any forum u might use
#147502 What Does This Mean?
Posted by D4nz0 on 07 October 2011 - 11:30 PM
all of em have this? Don't think I've seen it
#147498 ! Guide ! Mk7 Fog Lamp Change
Posted by D4nz0 on 07 October 2011 - 10:39 PM
If you have any questions, just ask, I know the guide doesn't go into great detail but hopefully this guide will help someone, sometime.
I don't think there is anymore detail needed... although what some would consider a very simple job to do..... its a great post that will definitely benefit someone that has maybe a lack of confidence in doing the job themselves, once they see how little there really is too it.
I'm a big fan of How To's for everything... especially the easier jobs, purely because they actually benefit more people and make people braver to take on bigger jobs.
Nice post ;)
#146280 A Soloution To My Smashed Fog Light
Posted by D4nz0 on 29 September 2011 - 12:05 PM
As long as they take the same bulbs as Ford oem fogs, I'd definitely get these ones if i.needed em. The webpage doesn't state what bulbs are used.
Lenny is exactly right, a few pics and a 'how to', even for a simple job, will give less experienced motorists the confidence to do these sorta jobs themselves. I know far too many 40yr olds that are too scared to remove headlights!!
#145888 Ben... - Panther Black Mk7 Zetec S Tdci
Posted by D4nz0 on 26 September 2011 - 08:04 PM
looks good Ben. Wasn't sure if you'd do HID's due to the "legality" issue.... knowing how detailed you like to be.
Changing the sidelights to xenon white 501 led's? Will finish off the final touch to the HID's
#144876 The Mrs Fez
Posted by D4nz0 on 20 September 2011 - 06:59 AM
So do I, but your sense of humour is a very dry, cheeky humour, probably best kept for people that know you... because I don't know you and you just sound like you're being silly.
[EDIT BY DANGULL]: Firstly, that type of language is not acceptable on FOC, secondly directing it at another member is most definitely not acceptable on FOC, and thirdly you'll find quite a lot of 'dry' humour and banter on FOC. cyb is a long standing member who contributes a lot to the forums - so lashing out is not really what's called for thank you.
#144770 The Mrs Fez
Posted by D4nz0 on 19 September 2011 - 01:49 PM
should have- you can tell by looking at the windscreen, sensor is in front of the mirror, but I can't see it as someone has parked a low spec zetec in the way :D
My 'low spec zetec' isn't in the way of the windscreen, but thank you for the mature response
#144701 Ben... - Panther Black Mk7 Zetec S Tdci
Posted by D4nz0 on 18 September 2011 - 09:26 PM
ROB, open your bonnet, pull of the carpety stuff on underside of bonnet (or just the edges, enough to see jets, and see if they're plugged into anything other than a rubber hose. If so, they're heated.
#144657 The Mrs Fez
Posted by D4nz0 on 18 September 2011 - 06:28 PM
Parking sensors have never been standard, but the Bluetooth and USB have been standard since late 2009/early 2010. You should also have 6 speakers as standard in Titaniums since the very first build.
July 2010 onwards build get the 8 speaker Sony radio, bluetooth & USB.
ahh right, its a 58 plate.
The Arnold Clark website had the wrong spec list then.... but she's not too bothered tbh. Thanks for the replies
#142556 Ben... - Panther Black Mk7 Zetec S Tdci
Posted by D4nz0 on 02 September 2011 - 07:19 PM
It's gonna be a very lucky person that buys your car once your done with it.... especially if they like cars with loads of features and extra benefits.... and don't like like a boy racer has driven through halfords with his dads credit card.
Love watching this thread.
