Support the club!
chrismar
Member Since 17 Jun 2011
Offline Last Active Jan 24 2013 08:49 PM
In Topic: Tdci Fuel Pump Tools
24 January 2013 - 09:57 AM
In my opinion and only my opinion the pump is not your problem, but its the injectors i had a very similair issue with my mondeo tdci 115hp 54 plate would put the flashing glow plug light on when the engine was under load traveling up hill then after a while of doing that would put the light on then cut out once the clutch was depressed. i had a leak off test done and 3 of my injectors are leaking back in excess causing the pump to be unable to cope with the fuel quantity demanded and that is what throws the code up p0211 i was also getting p1211 fuel pressure related again.
try a leak of test at a local mechanic cost is not much and will shed some light on your problem. you more than likely have the same problem as i had as the symptoms are near identical
23 January 2013 - 10:20 PM
Try here http://www.ebay.co.u...=item460853b2bc for the tools you require.
it is believed that as the pump breaks down metal particals go up the high pressure outlet and into the injectors damaging the injectors, they are aslo returned to the tank via the return line from the pump. it is recommended with pump failure to remove the tank clean and flush, clean out all lines replace the filter, the pump the injectors and all high pressure lines to be completely confident that all metal particals have been removed from the system.
quick question what year is your car and what leads you to belive your pump is breaking down?
In Topic: 2005 Mondeo Tdci Cuts Out On Return To Idle, Help Please! :(
23 January 2013 - 04:40 PM
What was yours doing pal? Exactly, any lights on etc etc?
mine was putting the flashing glow plug light on when travelling up hill or if you failed to change down early enough and put the engine under increased load had codes p0211 and p1211 strong smell of diesel at front end increased fuel consumption calculated not trip computer and fluctuating fuel rail pressure viewed as live data
22 January 2013 - 10:50 PM
i too have a solid fly wheel fitted and have found it to be no trouble. i borrowed a friends generic code reader when my car played up ( has 3 injectors leaking back to much) it was autel he uses it on vw's all the time and works fine. connected to my ford showed nothing but f super showed 2 codes my suggestion is try a different code reader that will read ford specific codes
22 January 2013 - 08:15 PM
f super will code the injectors on a 2005 tdci i have used it on my 54 plate 115hp and worked fine also reads and clears the dtc's as well as displaying live data.
