adowling
Member Since 17 Jun 2011
Offline Last Active May 13 2012 01:31 PM
In Topic: How To Fit New Front Lower Grill On Mk2.5 Focus
15 April 2012 - 06:42 PM
I'm having no luck! i've tried your method but it isnt budging at all :(
In Topic: Drl Installation Help Needed!
17 June 2011 - 07:21 PM
Add a relay to the DRL circuit. Keep it wired to the switch the way you have it. Wire it on the closed side of the relay so the circuit will be connected when there isn't power.
use the headlamp circuit to power the relay so when the headlights are turned on, the relay opens
Thanks. But will the DRL's be on when the keys aren't in the ignition? because you can turn the side lights on when theres no key. So when the lights are off, i guess there's still power going to the switch, just no circuit to be made. But when there are DRL's installed, surely it would create a circuit when the keys aren't in the ignition?
Sorry if i've confused you.
Cheers.
