mrtickle666
Member Since 30 Jun 2011
Online Last Active Today, 06:26 PM
In Topic: Radiator Fan Always On.
13 May 2015 - 11:30 AM
I've cleared the faults and its stopped. Don't know whether it's a temp fix or not.
12 May 2015 - 02:14 PM
No dpf is fitted. I take it's likely to be the coolant thermostat as the dash displays engine temp correctly.
12 May 2015 - 09:41 AM
I've reseated all relays, no joy. I can hear clickjng but not sure if fan. I cannot work out which relay is fan as where the diagram shows a fan r12, there is no relay!
In Topic: New Dvd Satnav Unit Fitted (Pics)
11 May 2015 - 10:18 PM
Hi There,
I've narrowed my search for a head unit down to this one for my 2006 focus TDCi
Could anyone advise if this will be just plug and play or will require additional cables? not sure if this has the canbus (does that just enable the steering wheel stalk?)
I'm looking at one of these. I couldn't find a Manual online. Do you have a link?
11 May 2015 - 09:47 PM
Thanks, I found them, I just cannot work out which one it is. Should I hear it switch when the ignition is on if it it working?
