Jennie, do yourself a favour and have a leak off test done at a reputable diesel garage. I had the same problem as you and was advised to do this. It took me 9 months before I did this and wish I had done it sooner. This may save you a lot of time and expense in changing parts that do not need to be replaced.
- → Viewing Profile: Posts: George Lawrence
Support the club!
- Group Members
- Active Posts 46
- Profile Views 595
- Member Title Settling In Well
- Age 52 years old
- Birthday October 14, 1960
Gender*
Male
Ford Model
Mondeo 2.ltr tdci auto estate
Ford Year
2003
UK/Ireland Location
Hertfordshire
Annual Mileage
5001 to 10,000
Interests
Classic Cars
General Automotive
Travel
Food & Drink
Entertainment
General Automotive
Previous Fields
Location
Stevenage Herts
In Topic: What Else Could It Be?
18 May 2013 - 05:58 PM
In Topic: 2004 Mondeo Diesel Flashing Glowplug Light??
14 May 2013 - 08:08 PM
Hi Guy's, I have had the same problems as you. please do yourselves a favour and have a leak-off test done on your injectors. this will not only save you time but also cash. Martin my codes were read and came up with the same answer as yours, changed the pump and still the same problems. I was advised to have a leak off test as these codes can be misleading. ALL THEY ARE TELLING YOU IS THAT THERE IS A PROBLEM WITH THE HIGH PRESSURE FUEL SYSTEM. PLEASE HAVE A LEAK OFF TEST AND SAVE SOME TIME AND MONEY. George
In Topic: Ford Mondeo 2L Tdci Problem.
08 April 2013 - 03:35 AM
Good morning Barry,
I have had the problems you are experiencing. Stoney is correct in the advice he has given you, like a lot of other guy's on this site they are very knowledgeable. Save yourself a lot of time reading all the posts and advice on this fault it get's very frustrating because there are so many views on what can cause this. Book into a diesel specialist, not fords or your local mates garage. Get them to do a leak off test and they should be able to determine the cause of the problem. the chances are it's not going to be cheap but it will save time and you can make the decision on whether it is cost effective to get it done. good luck and let us know how you get on.
Cheers George
Cheers George
In Topic: Injector Socket Size
05 April 2013 - 06:17 PM
Hi All, Got the socket and stripped everything back as explained in other posts. the only problem is, when I put the socket over the Injector, it doesn't drop down far enough to get a grip on the nut. Do you have to take the top half of the injector off first? ie the part where the fuel pipes, leak off pipes and the electrical connectors attach. any help will be appreciated.
Cheers George.
Cheers George.
17 March 2013 - 07:55 AM
Thank you for that info, hopefully I can get it sorted asap.
George
- Privacy Policy
Find content
Latest Comments
More
