Member Since 10 Jul 2011
Offline Last Active Jan 11 2015 03:05 PM
In Topic: Mk1 Front And Rear Washer Issue
11 January 2015 - 03:06 PM
Gave it a go. Also used a pump where the water goes to see if that'll push it at all.
The back wiper worked a bit better but not at a decent standard and the front kicked in shortly.
Without having to jack the car is there anything we can put in their to clear a possible block?
08 January 2015 - 12:07 AM
Thanks, we'll have a look over the weekend.
Was just water on its own - I'll spend some time and see if it kicks back in if there's been any freeze blocks over Xmas while it was just sat there.
In Topic: Faulty Vss
31 October 2014 - 07:25 PM
Replaced the VSS and today the car still cut out.
Any idea on what would now be causing this? From what I've read the VSS seemed to sort this. All the same symptoms.
25 October 2014 - 12:03 AM
Not too sure, I'll have a look tomorrow.
What would be the issue if it wasn't a lead acid battery?
In Topic: Using The Correct Oil
01 September 2014 - 08:39 PM
Ok, thanks :)
