Member Since 03 Nov 2008
Offline Last Active Apr 07 2009 10:30 AM
In Topic: engine issues
17 February 2009 - 08:50 AM
I stripped the pipes out over the weekend and found one of the fuel return pipes was badly cracked, so I replaced them.
After reassembly of all the pipes I now canít get the engine to fire.
I am not seeing any fuel coming down the fuel pipes from the pump. I know there is fuel getting to the pump but it doesnít seem to be forcing the fuel down the lines. Any Ideas?
10 February 2009 - 09:40 AM
Thanks, Ill have a look over the weekend.
09 February 2009 - 04:12 PM
It isnít as bad when it gets to temperature but itís still present
Sounds like this
In Topic: Will not start
03 November 2008 - 06:04 PM
Just got back home and looked at all the fuses. They all seem fine.
I put my key in and and turned it to start it and the windscreen wipers came on.
Im going to have a guess and say its an electrical issue.
In Topic: Alarm Keeps Beeping!
03 November 2008 - 09:37 AM
I had a similar issue but after replacing the bonnet switch it fixed the issue. You can just remove it but the alarm might not come on but its a good test to see if it is that switch.
