optimadam
Member Since 03 Nov 2008
Offline Last Active Apr 07 2009 10:30 AM
engine issues
09 February 2009 - 11:40 AM
Hi all,
I have an issue with my engine that I’m having trouble diagnosing.
When the car is running idle I get a lot of white smoke from the exhaust and the engine coughs. The smoke smells a bit like oil or diesel being burn off but I know white smoth mean water.
I thought it might be the head gasket but I don’t seem to be losing much water or oil and it only happens when idle
Car is a mondeo estate diesel 1996
Anyone know what the issue could be?
Will not start
03 November 2008 - 09:23 AM
I just signed up to see if you lot could give me any suggestion about what could be wrong with my car.
I own an estate 1.8D LX 96 N reg
This morning I put my key in the ignition and let everything charge up as normal, waiting until all the lights went out. Then turned the key to start the car and all the needles went to the right and then that was it, the engine didn’t even try to start.
Now every time I try to start it nothing happens. I thought it might be the battery so I tried jumping it but no sign of life. The lights in the car, central locking etc work fine, just not the driver’s console.
I was thinking that there was a surge and it blow one of the fuses, which I’ve not had time to look at right now as I had to get to work. Could it be the ignition barrel?
Any suggestions would be great.
