COSTESSEY GEOFF
Member Since 25 Jul 2011
Offline Last Active Sep 17 2012 01:48 PM
In Topic: Soft Top Problems :(
31 July 2011 - 11:05 AM
Hi Elfy my wifes streetka proloem with storage compartment but hers made a noise when button pressed but not opening main ford dealer put new arm in ok now
In Topic: Streetka Noise
29 July 2011 - 06:26 PM
DELLBOY MY WIFES CAR IS A STREET KA ONLY TWO SEATS
29 July 2011 - 06:24 PM
this may sound silly but it happend to me
pull the rear seat down & tighten up the bar that the seat clips into
i had similar & that was the problem it came loose
also open petrol flap & check the actual fuel filler cap & pipe is tight
as from memory it's a single screw that holds the pipe neck to the body of the car & that screw mayhave come loose
28 July 2011 - 08:46 PM
THANKS FOR REPLY DELBOY HAVE JACK WRAPPED IN SPONGE AND SPARE WHEEL FASTEN WITH BOLT
28 July 2011 - 08:42 PM
i would also remove the jack etc from the boot area & spare wheel then try the car over rough ground
sounds like a process of elimination.
if you hace wheel covers check the rear one ie remove it as sometimes there it a cap
on the hub that can come off then make the odd bumping noise
