Member Since 09 Aug 2011
Offline Last Active Mar 09 2014 05:08 PM
In Topic: Engine Malfunction Help Please :(
09 August 2013 - 10:59 PM
do you mix diesel sources ? sometimes (normally in v cold weather) differently sourced they react and clog the fuel filter, get a little warmer (after you are forced to stop?)  they then work ok. That said the common rail 1.9 VW engine is not that sensitive.
In Topic: 1L Ecoboost Possible Problem :s
09 August 2013 - 10:50 PM
Injectors. get to the dealer again and get the concern noted - they may have the correct technical answer or a Tech Service Bulletin on the topic. The most senior Ford guy in the UK & Europe is Steve Odell his email is: sodell1@ford.com - let him know if you don't get a fix
In Topic: Bike Carrier / Tow Bar For S-Max
05 July 2013 - 06:16 PM
as regards cutting the bumper - this is a cosmetic cover and has no structural purpose at all - the Ford twobars required the bumper to be cut (not a visual location). remember the Titanium X is a no go at all for towbars because of the rear bumper. OF course having a towbar and necessary electrics fitted and the software update is around £400 minimum
In Topic: Winter Diesel Additives, 1.6Tdci Blocked Fuel Filter
15 March 2013 - 07:33 PM
exactly the same problem with same spec engine, 6 months old C-Max. and the recommendation from Ford Tec colleagues was to stay with one brand of fuel when the temp is around zero. The car was put into a Ford Dealer (Essex Ford) and the words of wisdom I was given 'we have had a lot of them' ah well. The main concern was the way it failed - I was only able to drive at the limit of fuel supply, max 15mph, not to bad but this was the M25. It can be cured by sitting and running the engine and if you are lucky the heat will lift the temp to allow the fuel to run - took half hour for my car.
