Maggsy
Member Since 18 Aug 2011
Offline Last Active Oct 07 2011 05:45 PM
Central Locking Issues Please Help!
07 October 2011 - 05:45 PM
hi all, more problems with my focus, central locking this time.
im using the key to unlock and lock the car until i get remote fixed.
first the driver side rear door stopped working with the central locking but locked & unlocked manualy, now it is locked and wont unlock atall.
i cant get to the lock as i cant get to the screws to take the panel off because the door wont open.????
now happening also is that when unlock drivers door doesnt always work the central locking, i have to go round to the passengers door and do it that way.
please help, central locking nightmare!
Idle Control Valve
16 September 2011 - 10:04 PM
HI GUYS.
LOOKING FOR A 'HOW TO' TO CLEAN THE IDLE CONTROL VALVE.
TO BE HONEST NOT EVEN SURE WHERE IT IS ON A 2.0L FOCUS?
IS IT IN THE THROTTLE BODY ON THE SIDE OF IT??
I AM ASSUMING THEY CAN JUST BE CLEANED WITH CARB CLEANER AND PUT BACK ON???
Key Remote Problems
14 September 2011 - 07:09 PM
IT'S THE 3 BUTTON REMOTE WITH KEY IN QUESTION.
SENT THE REMOTE PART OFF FOR REPAIR AS IT DIDNT WORK OR SO I THOUGHT.
RECIEVED IT BACK WITH NEW SWITCHES BUT IT STILL DOESNT WORK.
HAVE TRYED THE RE-SYNC - 0N OFF 4TIMES, CAR SOUNDS TO INDICATE READY. BUT WHEN I PRESS ONE OR ALL OF THE BUTTONS NOTHING WORKS,SUGGESTING IT DOESNT RECOGNIZE THE REMOTE.
ANY SUGGESTIONS GUYS??
THANKS!
Dtc 9202 Fuel Sender Open Circuit
14 September 2011 - 06:50 PM
HI ALL!
OK SO FILLED THE CAR TO A FULL TANK THE OTHER DAY-NO PROBLEMS
TODAY (35MILES LATER) THE FUEL GAUGE STAYS ON EMPTY.
I HAVE DONE THE DASH TEST AND GOT DTC CODE 9202 = FUEL SENDER OPEN CIRCUIT.
MY QUESTIONS ARE...
IS THIS SERIOUS?
WHAT HARM WILL IT DO?
DOES ANYONE KNOW WHAT IS NEEDED TO GET THIS FIXED-PART NUMBER ECT?
IS IT AN EXPENSIVE JOB TO GET DONE?
ON THE DASH TEST...
FUEL READING WAS - F255
OIL READING WAS - O 155
BATTERY VOLTAGE WAS - B155
OTHER SYMPTONS LEADING UP TO THIS....
CAR HESITATION
CUTTING OUT (REVS DROP TOO LOW WHEN STOP/DIP CLUTCH)
SOMETIMES REVS INCREASE WHEN CHANGING GEAR/DIP CLUTCH
WOULD THESE SYMPTONS BE RELATED??
PLEASE HELP! ANY ADVICE WELCOME!
MANY THANKS!!
Radomly Feel The Engine Miss A Beat/hesitate
18 August 2011 - 04:01 PM
hi all new to the site and a new owner of a ford focus 2.0 petrol hatch.
problems....started off with rough idle down to a broken vacuum pipe (assume it's a vacuum pipe as it sucks where the brake in the small pipe was) now fixed the rough idle is gone (maybe still a slight bit but might just be me).
now i've noticed that when cruising at any speed but mainly on a motorway at 70mph, the car will miss a beat/hessitate. it fells like someone has touched the brakes and then it picks up again, sometimes for a split second and sometimes for 1-2secs.
have noticed that at this time the revs seem to stay about the same but speed drops????
any ideas???
thanks!!
