Member Since 25 Aug 2011
Offline Last Active Aug 20 2012 09:52 PM
In Topic: Rapid Temp Gauge Movement
26 July 2012 - 04:14 PM
Thanks :D
I just found a video on youtube of how to flush out an engine and replace the thermostat (shame it was a 1.3 endura though!) but i think i know enough now to have a go. When i replace the hcv and possibly thermostat, is it worth me sort of blasting the hose through the heater matrix pipes to clean the gunk out?
In Topic: Ford Fiesta Sidelight/stereo Problem?!!!!
26 July 2012 - 04:12 PM
haha i thought as much, sounded like someone confused the illumination wire with the power/ignition wire :P
26 July 2012 - 03:47 PM
Hey Lenny, Thanks for the reply :)
I did consider head gasket but as im loosing neither coolant or oil (and i did the check you mentioned, and my oilcap has dark black oil on it) so i knew i could at least put that conclusion out of the window.
Is there something special i am to put in the coolant system? I was just aware that water was all i need (and obviously a mixture of anti-freeze). Learn new stuff all the time aha :) How do i do a coolant system flush and refill? The only real way i know of refilling a coolant system is running the engine with the cap off and slowly filling it as it goes down (something dad showed me) if there is a better proper way of doing it i would for sure give it a go :)
In Topic: Cv Joint Failure?
25 August 2011 - 05:53 PM
wheel shake at 60-70? could be wheel weights need balancing, loose wheel nuts, track rod end joints..
In Topic: Hi All...
25 August 2011 - 05:43 PM
hey steve! what issues are they?
