dreadz
Member Since 01 Sep 2011
Offline Last Active Feb 13 2015 07:42 AM
#417304 P0428 Dtc After Dpf Removal
Posted by dreadz on 07 October 2014 - 09:44 PM
Good job mines a euro 4...apparently only tailpipe inspections will show missing filters, which the UK are trying to do away with. Obd will be used to read fault codes... No talk of forced regens etc.
#416936 P0428 Dtc After Dpf Removal
Posted by dreadz on 06 October 2014 - 07:51 PM
Actually decided to have a good read about German pti... Very interesting and some of the research behind the tests was intriguing too. The obd looks for faults etc and general running measurements and compares to manufacturer... I'm sure someone will be able to program those figures into ecu to fool it.. But i will agree with you that there will be more in depth testing coming but some years off. They are saying that even the German pti tests are not picking up everything and needs changing! Once the crack it then prob see changes here. But it's also looking at filters for petrol too lol
#416921 P0428 Dtc After Dpf Removal
Posted by dreadz on 06 October 2014 - 07:11 PM
Also reading into how the German test works... If you can't communicate with obd then it defaults back to normal test...so it's not a fail if for some bizarre reason it doesn't work!
#416868 P0428 Dtc After Dpf Removal
Posted by dreadz on 06 October 2014 - 04:42 PM
And if your that concerned that they will plug in some fancy machine in your port, then you can easily disable it by removing a wire or fitting switch elsewhere... When connected it won't read... Can't fail it for that.. Or can they lol
#416867 P0428 Dtc After Dpf Removal
Posted by dreadz on 06 October 2014 - 04:39 PM
And you can always claim you bought car in that condition to insurance... Let them prove otherwise if your caught, that's down to them to do not other way round!
#416866 P0428 Dtc After Dpf Removal
Posted by dreadz on 06 October 2014 - 04:38 PM
Yawn.... Not this argument again... My friend is mot tester blah blah.... We had this back in the year before new tests came out and to be honest i know no one who had failed? All these checks that were supposed to come? Where are they? Instead of posting what you have heard post proof... Until then people remove, block whatever you want! Mine flew through with better results than last year! Figure that?
#412886 Focus 1.6 Tdci Problems
Posted by dreadz on 24 September 2014 - 04:09 PM
Fuel filter my friend... Had exact same issues.... Get it changed before spending any other money
#391887 1.6 Tdci -2007 - Dpf Removed And Remapped!
Posted by dreadz on 30 July 2014 - 04:32 PM
just cut open and insides removed then welded back up. i also had no undertray cover fitted-so the tester could se it more openly...very risky move but no concerns from him. only had removed as it makes it easier when changing oil/filter.
#391834 Dpf
Posted by dreadz on 30 July 2014 - 03:23 PM
well MOT time today and sailed straight through no problems what so ever- was dreading it due to dpf removal. and emissions were excellent according to Tester!! happy happy happy
hows yours running at moment buddy?
#391832 1.6 Tdci -2007 - Dpf Removed And Remapped!
Posted by dreadz on 30 July 2014 - 03:22 PM
#391830 Mk2 1.6 Tdci Stalling
Posted by dreadz on 30 July 2014 - 03:19 PM
try a fuel filter change buddy- had similar symptoms on my focus tdci :P
#379133 Dpf
Posted by dreadz on 27 June 2014 - 03:10 PM
glad to hear it pal..best thing i ever done. did you get the egr deleted from ecu too? keep us posted on how it goes and any issues.
#375973 Engine Stalling On Accelerating
Posted by dreadz on 18 June 2014 - 12:26 PM
go for the fuel filter change first...had this exact problem too and was easily resolved by changing :P
#374841 Dpf
Posted by dreadz on 15 June 2014 - 10:19 AM
glad you hopefully getting sorted pal. just didnt want to see you ending up with the crap method that others have fallen for. keep us posted .
i had egr delete done when mine was remapped. just saves any further problems down the line. consider blocking off with blanking plate mate if not already done(cant remember if u have or not hahaha)
#374768 Dpf
Posted by dreadz on 14 June 2014 - 09:09 PM
http://avontuning.co.uk/
