Member Since 13 Nov 2008
Offline Last Active Dec 17 2008 08:00 PM
In Topic: Odd noise when pulling away
16 December 2008 - 06:55 AM
check if it does it in all gears or just first i had a similar problem on my escort gti and it turned out to be the gear oil was low
In Topic: mk2 xr2 intermittent stalling problem
16 December 2008 - 06:53 AM
hey m8 check the airfilter and any pipes vaccum leaks around the carb its probably something and nothing like a cracked pipe
In Topic: sub vibrating interior trim
16 December 2008 - 06:50 AM
cover your boot all over with dynomat soundproofing stuff mine dosent rattle inside but its rediculous outside
In Topic: zetec conversion
30 November 2008 - 01:26 AM
ive got an xr2i on a 1993 k plate n all u need to do is swap the head and throttlebody get a decent exhaust and whack a chip in it u should have around 150 bhp like mine pretty good fun till it rains then its like a boat
In Topic: loss off power
29 November 2008 - 08:28 PM
first off check the lambda sensor and the air flow sensor common on most fords
